I have added a spellcheck button to the ButtonsLeft collection of an editor control for use in a grid. My user clicks the button when they want to spell check the contents of the cell. I am setting the EditorControl property of the cell in code and I am setting the Spellchecker property of the grid column as well. The event fires when my user clicks the button and the spellchecker finds the error properly. However, nothing happens when I attempt to show the spellchecker dialog. I have tried several arguments for the dialog and none have worked. I am guessing the problem lies in the fact that I am using a different editor control and not just the cell itself. I have tried all combinations that you see commented out below. Any ideas?
If xForm.UltraSpellChecker1.CheckText(grdCell.Text).Count > 0 Then
'xForm.UltraSpellChecker1.ShowSpellCheckDialog(txtBox)
'xForm.UltraSpellChecker1.ShowSpellCheckDialog(Ctrl)
'xForm.UltraSpellChecker1.ShowSpellCheckDialog(grdCell)
xForm.UltraSpellChecker1.ShowSpellCheckDialog(grdCell.EditorControl)
xForm.Refresh()
No go on that one either. I'll report it as a bug.
Try using the EditorResolved on the cell. If that still does not work, it could be a bug and I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
