160
FlowLayoutManager in 8.3
Hi there,
I have just upgraded our project to use the latest controls and it appears that the FlowLayoutManager is not working. We are adding custom controls containing images to a panel which the layout manager has been configured to use. When we add the controls to the container nothing appears. If I remove the layout manager then the controls appear again but are obviosly not aligned. No errors are raised. This was working perfectly with the 8.2 release.
 Any ideas?
  • 45049
    Can you reproduce this in an isolated sample application, which works under NetAdvantage for .NET 2008 Volume 2 but not under NetAdvantage for .NET 2008 Volume 3?  If so, then please submit a support request and attach that sample, and we'll investigate this in more detail.  If it turns out to be a bug, we'll get it fixed and ensure you're notified when that fix is released.
