640
How to Call Validating Event in Button Click Event
Hi Everyone
How to fire a Ultratextbox validating event in Ultrabutton Click event. I tried it usually like these following two methods both throws same errors like this
Method 1:
private void uiButton1_Click(object sender, EventArgs e)
uiTextBox_Validating(this, CancelEventArgs.Empty);
Method 2:
uiTextBox_Validating(this, e);
It throws some errors like
Error 2 The best overloaded method match for 'Task_2_Control_Panel.FrmControlPanel.uiTextbox_Validating(object, System.ComponentModel.CancelEventArgs)' has some invalid arguments D:\Task 2 Control Panel\Control Panel.cs 1225 13 Task 2 Control Panel
Error 3 Argument '2': cannot convert from 'System.EventArgs' to 'System.ComponentModel.CancelEventArgs' D:\Task 2 Control Panel\Control Panel.cs 1225 44 Task 2 Control Panel
Could anyone help me to sort this issue.
Thanks in advance
Ferdin
  • 5
    I too had the same problem when I tried to fire a validating event within a ButtonClick event.I went through the reply answer to ur post.But answer is not clear to me as well
    ferdin said:
    Hi Everyone
    Method 1:
    Method 2:
    Thanks in advance
    Ferdin
  • 69832
    The Form class exposes a method, 'ValidateChildren', which triggers the Validating event for each child of the form. If you want to call the event handler directly, you should not use CancelEventArgs.Empty, but rather a new instance of CancelEventArgs, because the static Empty property is inherited from the System.EventArgs class, and you need a strongly-typed CancelEventArgs instance to call the event handler directly. Also, the value of the 'sender' parameter should probably be uiTextBox, not this, in case the handler logic is expecting the sender to be of a specific type.
