120
Unpinning dockareas changes position.
I am using dock manager to control panes on my screen.
I have pin buttons enabled on the dock areas.
There are two dock areas(Docked top) split horizontally and under them there are two areas split vertically(Docked right). When i unpin right one of the vertical pane, it repositions to right showing tab button and covers the above two horizontol panes. What I wan is that the un pinned tab button should not be shifted to top.
Can anyone help me.
  • 44743
    I believe this is intentional behavior. An unpinned pane docked on the right or left will span the entire height of the Form when it is flyed out. If you mouse off the pane though, it should fly in to the right side.
