Hi!
I have a grid and I need to print to pdf different views of this grid (using different filters).
So I do like this:
Report report = new Report(), report2 = new Report();
this.ultraGridDocumentExporter1.Export(this.gridViewWaste, report); report.Publish(@"C:\Temp\mila.pdf", Infragistics.Documents.Report.FileFormat.PDF); // I am changing grid filters and visible columns here)
this.ultraGridDocumentExporter1.Export(this.gridViewWaste, report); report.Publish(@"C:\Temp\mila2.pdf", Infragistics.Documents.Report.FileFormat.PDF);
As a result - both pdfs are the same and contains first view of the grid. If I export grid after filtering to report2 and publish report2 to mila2.pdf - mila.pdf and mila2.pdf contains two different views of the same grid as it is supposed to be. How to get those two views in the same pdf?
I see. It works! I was exporting not to section but to the report before - this is the problem.
I'm not sure I understand your question. You can export different grids to the same report by passing in an ISection to the exporter, such as:
Report report = new Report();ISection section = report.AddSection();this.ultraGridDocumentExporter1.Export(this.ultraGrid1, section);section = report.AddSection();this.ultraGridDocumentExporter1.Export(this.ultraGrid2, section);
If your grid layout is pretty simple, you could even export it to the same section, though you may be better off doing it as I posted here.
-Matt
