I am not able to install infrgistic control for windows form application.
i got an error while attempting to add the infragistic components to the toolbox..It shows that a log file has been created to solve the problem.but that file is empty.I did run as administrator..I dont knw y i am getting this error..Pls help me if u guys have any idea!!
I am using windows vista.avg anti virus ,vs 2008 and dotnet3.5 version
Thanks .It helps me alot!!it is working now
Have you installed the toolset, but are just having problems running the Toolbox Utility? If so, what is the error message you're getting, and what version of the toolset did you install?
The Toolbox Utility is simply a shortcut to creating the toolbox tabs in Visual Studio. You can create these manually, as detailed in the following two articles from our online help documentation for NetAdvantage for .NET 2008 Volume 3:Using the Choose Toolbox Items Dialog BoxDragging Assemblies from the Bin Folder
