205
How can I define columns in the grid at Design-time & retain in run time.
HOWTO:How can I define columns in the grid at Design-time and bind them at run-time so that some fields of the data are excluded from the grid?
I was going through the above example from knowledge base.
I did define the band and columns with name and set up all properties but at the run with setbinding method it takea all the properties from the data source. Is there anyway I can keep the setup from the design time to thr run time when I am attaching my table at run time.
 Sandy
