Hi Ravi,
I am pretty sure that this was fixed, but I could be wrong, and I am not sure what versions.
You should Submit an incident to Infragistics Developer Support and ask them. They can probably give you a more definitive answer about whether this was fixed and in what versions.
Hi Mike,
Has the above mentioned bug been fixed ? I am struck with the same issue.
I am using verion 7.2
Do let me know.
Ravi
Assuming it works for any other error code, it sounds like a bug to me. You should Submit an incident to Infragistics Developer Support.
