In our application, we have a number of editable UltraWinGrids with columns that have ColumnStyle.DropDownList. Our users have encountered a usability issue because of the following:
Suppose you click a cell in a column of this type, and then, to navigate away, you press the up or down-arrow keys or you move the mouse scroll wheel. Without realizing it, you have put the row containing the cell into edit mode *and* changed the selection in the drop-down list. Then, if you click outside the row, the change gets committed back to the database.
Without realizing it, you have corrupted your data.
Is there a way to get around this without abandoning drop-down lists and Excel-style in-place editing? For example, can we modify the behavior of editable drop-down lists so you can't change the selection unless you first drop down the list by clicking its down-arrow button?
The best approach that I can think of is to handle the KeyDown of the grid and handle the event if you don't want this behavior to happen. The following code worked for me with a ValueList assigned to the column with a Style of DropDownList:
private void ultraGrid1_KeyDown(object sender, KeyEventArgs e){ if (e.KeyCode != Keys.Up && e.KeyCode != Keys.Down) return; UltraGridCell activeCell = this.ultraGrid1.ActiveCell; if (activeCell != null && activeCell.Column.Key == "Col 2" && activeCell.ValueListResolved.IsDroppedDown == false) e.Handled = true;}
As for the MouseWheel, I'm not really sure that there's a way to cancel this one, but I'd think the Up/Down keys are the ones that would give you more problems for navigating across the rows.
-Matt
