175
Edit a cell's value somewhere?
In Excel, if we click on a cell, the cell is select, but the cell doesn't enter the edit mode,
we can see the cell's value appears on the top of the sheet's header(the control looks like a Textbox,
now i just consider it as a Textbox), then we can edit the value here. The effect is the same as we directly
edit the cell by double clicking the cell.
Does the WinGrid also provide such a Textbox on the top of the header let us edit the cell's value
in such a way?
here is a demo picture about this solution
  • 37774
    There is nothing built into the grid that would allow this.  You could certainly bind an external editor to the ActiveCell of the grid, such as:
    private void ultraGrid1_AfterCellActivate(object sender, EventArgs e)
        this.textBox1.DataBindings.Clear();
        UltraGridCell cell = this.ultraGrid1.ActiveCell;
        if (cell == null)
            this.textBox1.ReadOnly = true;
        else
            this.textBox1.DataBindings.Add("Text", this.ultraGrid1.DataSource, cell.Column.Key);
            this.textBox1.ReadOnly = false;
    You would also want to set the grid.DisplayLayout.Override.CellClickAction to CellSelect, and also set the AllowUpdate to False if you want to exclusively provide editing through the external control.
    -Matt
