Hello, i.e. I have two appointments the first one from 09:00 to 09:25 and the second one from 09:30 to 10:00. The timslot intervall is set to 20minutes. Now the both appointments will be shown side by side. It's possible that the second appointment will be shown below the first one, because the times are not overlapping. Only when the times are overlapping, the appointments should be shown side by side.
Hell Robert,
This functionality is also available when using AppStylist files. You could load a style (IG.isl) for example by:StyleManager.Load("IG.isl");
Then you could modify all appearances as you wish using the 'AppStylist' tool.
Please do not hesitate to contact us if you need any additional assistance.
By any chance has this functionality changed or is it still true in the latest controls that only the 2007 ViewStyle puts the appointments w/o overlap?
Is there a way to change the colors / borders to make the style look more like the standard styles?
That functionality is unique to the Office2007 ViewStyle; no other view style supports it.
Hello, is it possible to get the same appearance behaviour from Office 2007 ViewStyle in the other ViewStyles? Which property I have to set that the appointment shown under the other appointment when their times do not intersect independent of if their times intersect with one or more timeslot's.
I'm sorry but I don't understand your question. Under the Office2007 ViewStyle, the appointments will be shown one under the other because their times do not intersect. Under the other ViewStyles, they will be shown side by side because both of their times intersect with one or more TimeSlots.
