180
Binding WinNavigationBar to a DataSet
I am trying bind WindnavigationBar to a dataset
My code is as below
private void Form1_Load(object sender, EventArgs e)
this.newProductTableAdapter1.Fill(this.thunderCommerceDataSet1.NewProduct);
this.product_groupTableAdapter1.Fill(this.thunderCommerceDataSet1.Product_group);
this.ultraNavigationBar1.RootLocation.DisplayText = "NewProduct";
Infragistics.Win.Misc.UltraNavigationBarLocation location;
foreach (DataRow row in thunderCommerceDataSet1.Tables["NewProduct"].Rows)
object[ items = row.ItemArray;
location = new Infragistics.Win.Misc.UltraNavigationBarLocation(items[1].ToString());
this.ultraNavigationBar1.RootLocation.Locations.Add(location);foreach (DataRelation relation in row.Table.ChildRelations)
DataRow[ childRows = row.GetChildRows(relation);
foreach (DataRow childRow in childRows)
object[ childItems = childRow.ItemArray;
location.Locations.Add(childItems[0].ToString());}}}}}
I am getting an error  "Key already exists
Parameter name: Key" in this line
What is wrong with my code?
  • 69832
    Verified Answer
    The overload of the Add method that you used is setting the Key property, which has to be unique across the collection. There is another overload that takes two strings; the first is the key and the second is the value of the Text property. You should use this overload, specify null as the value of the first parameter (key), and assign childItems[0].ToString() as the value of the second parameter.
