865
Schedule and owner error
Hi
I am new to this contorl. i have two tables which one stores data for the schedule and the other stores the owner. When i run my application i get the following error message:
  1. There is already an owner with key ''5'.owner key must be unique.
  2. and then i get this error: Key already exist.parameter name:key
Could you tell me what is the problme please?
I checked the sample and noticed that there are duplicate key in the schedule table.
This is my code:
Private myDT As New DataTable("ServiceApp")
Private myDS As New DataSet
Private myDTOwner As New DataTable("ServiceOwner")
Private myDSOwner As New DataSet
Private Sub GetApponitmentSVC()
Me.CalendarInfoSVC.DataBindingsForAppointments.BindingContextControl = Me
Me.CalendarInfoSVC.DataBindingsForAppointments.SubjectMember = myDS.Tables.Item(0).Columns("JobNo").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.EndDateTimeMember = myDS.Tables.Item(0).Columns("CheckOutDate").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.StartDateTimeMember = myDS.Tables.Item(0).Columns("CheckInDate").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.OwnerKeyMember = myDS.Tables.Item(0).Columns("ServCatID").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.DescriptionMember = myDS.Tables.Item(0).Columns("Description").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.DataKeyMember = myDS.Tables.Item(0).Columns("ServiceHID").ColumnName
Me.CalendarInfoSVC.DataBindingsForAppointments.SetDataBinding(myDS, String.Empty)
End Sub
Private Sub GetAppointmentOwner()
Me.CalendarInfoSVC.DataBindingsForOwners.BindingContextControl = Me
Me.CalendarInfoSVC.DataBindingsForOwners.KeyMember = myDS.Tables.Item(1).Columns("ServCatID").ColumnName
Me.CalendarInfoSVC.DataBindingsForOwners.NameMember = myDS.Tables.Item(1).Columns("Description").ColumnName
Me.CalendarInfoSVC.DataBindingsForOwners.SetDataBinding(myDS, String.Empty)
End Sub
Private Sub ServiceFrm_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
myDT = MobService.ListServiceAppointments()
myDS.Tables.Add(myDT)
myDTOwner = MobService.ListServiceCategory(
False)
myDS.Tables.Add(myDTOwner)
GetApponitmentSVC()
End Sub
thanks for your help.
Kamal
