Inspite of my several experiments based on my understanding, I was not able to succeed to align the chart origin to (0,0).
I used a composite chart with a layer of type AreaChart. The labels on X-axis were starting from the minimum value
of the series data by default.The Y-axis was proper
I want the X-axis labels to be start from "0".
I tried by setting ulctrachart1.data.ZeroAlign = true, but even that also ended in negative
I tried setting X-axislabel item formattingstring to "<ITEM_LABEL:00.##>", but even this also negative
Any idea?
in an area chart, the x-axis is not a numeric scale, it's just a set of strings. only a ScatterChart or BubbleChart have both a numeric x-axis and y-axis.
try setting axisX.RangeType = Custom, axisX.RangeMax = numberOfDataPoints, and axisX.RangeMin = indexOfFirstDataPointToShow.
