Using the grid designer's feature picker, Fixed Headers, I've checked active and the columns to remain stationary during horizontal scrolling.
Additionally, I've set the grid's UseFixedHeader property to true.
The grid displays the fixed headers behavior in the designer as I'd expect, but running the app, no columns are pinned. I've also got groupBy mode enabled.
Are the two modes incompatible? Am I missing something?
Bill
You should be able to pin an individual column when you have columns grouped, assuming that you don't have a row layout or are using Groups and Levels. It's possible that the grouping operation is unpinning the columns, in which case you can listed to the AfterSortChange event (since sorting and grouping are closely tied) and re-pin the columns accordingly.
-Matt
