3455
Loading appearence from the xml, column width is not correct
I am loading the appearance from the saved xml.
this.UltraGrid1.DisplayLayout.LoadFromXml("");
Also each time when the application is exiting the appearance is saving to the same xml.
The issue I face is when the application loads and exits so many times the width of the column is reducing gradually.
I am also set this property
this.UltraGrid1.DisplayLayout.AutoFitStyle = AutoFitStyle.ResizeAllColumns;
Can any one suggest what is wrong with the procedure follwed?
Ceaser
  • 71886
    I was not able to reproduce your scenario, so I attached a sample in this post showing the process of saving and loading the layout of the grid. Please review the application and feel free to let me know if I misunderstood you or if you have any other questions.
    SaveAsXmlLayoutGrid.zip
