I have a composite chart with two layers, both displaying gantt charts (the top displays current times, bottom displays averages). What I would like is to offset the bottom layer or make its series boxes slightly wider so they are not completely obscured by the top layer.
Can anyone point me in the write direction.
You can try something like this:Create another Y axis.Set it's near and far margin to 5 percent - everything drawn against this axis will appear narrower.Make the top gantt layer use this axis.
