Hi All !
I'm searching on the Infragistics WebSite for a list of all available WinForms examples and samples ?
Claus
Starting with about 7.1 (if I recall correctly), all samples for all products are installed under <common documents>\Infragistics\<product>. So on XP, that's usually C:\Documents and Settings\All Users\Documents\Infragistics. On Vista, that's usually C:\Users\Public\Documents\Infragistics.
Also, in the Quick Start, there should be links to the samples folders.
I downloaded NetAdvantage_NET_20073_CLR20_SDK.exe
I can find the samples executables, where do I find the source files for them?
Do you mean http://devcenter.infragistics.com/Support/KnowledgeBase.aspx?
If you select Platform: Microsoft .NET - WindowsForms and check the checkbox that says Show only articles with samples, then you will get a list of KB articles having sample projects attached. Many of these samples are written for the version of the product listed in the "Information in this Article applies to" section of the article so they do not reflect features that have been introduced after the date on which they were published.
Current guidance can be found in the Windows Forms samples distributed with the downloadable SDK.
Hi !
Some weeks ago I've found a web page on the Infragistics web site with a list of all knowledge base samples but I can't rediscover this web page. Where can I find those list again ?
Thanks in advance.
We don't currently publish our WinForms samples on the Web. You'll need to download the NetAdvantage for .NET SDK to get a copy of those.
