I have inherited an app that exports the rows of a grid to an excel spreadsheet. How can I set the properties of an Excel column to the grid's column?
Simply, I want to set the excel column to currency like the corresponding grid's column.
Hi James,
DotNet formats aren't neccessarily the same as Excel formats. So the grid can't translate them for you automatically. What you should do is handle the InitializeColumn event of the exporter. This event wil pass you the format applied to the grid column and allow you to set the corresponding Excel format. A lot of times they are the same and you can just set one to the other.
