360
usercontrol properties not being saved to the windows form designer
I have a user control which contains 2 infragistics control (combobox and a textbox)   I have  2 properties on my user control which expose these controls.  The issue I'm have is when I change a property on the control such as appearance.forecolor in the propeties window and save the form and open the form back up the  property value is not saved.  How do i get the property value to save in the designer  am i missging an attribute?
john
public TextBox  MyTextBox
{get {return MyTextBox; }
public ComboBox MyComboBox
get {return MyComboBox;}
  • 17259
    To fix this issue you need to add an attribute to your properties:
    [DesignerSerializationVisibility(DesignerSerializationVisibility.Content)]
    But, I think you're using a UserControl in the wrong way. A UserControl should follow the encasulation rules and not expose its internal objects (what happens if you set the TextBox to null?), so expose only the properties you need, for example:
    exposing a label text in the head of the control.
    public string HeaderText
       get { return lblHeader.Text;}
       set { lblHeader.Text = value; }
    To set the font of all controls in the UserControl, just change the UserControl font and it will effect all its children font.
