Hi Everyone
I have Ultragrid and i have column called text where there is some text and other columns like font-family,style,size,weight,color,backcolor,border and bordercolor. If i change some values in this it should get reflected in the text column according to the chosen values from all these.
I tried to do it in but i couldn get it i dont know where i have gone wrong.
Is there any way to do it.
Colud someone help me please
Thanks in advance
Ferdin
Hello Nitin,
Thank you for the feedback.
My answer will be marked by my superior.
Could you please create new threads(questions), it would be easier for me to follow them and it will improve our search functionality for the other community members. Thank you in advance. Please let me know if something comes up!
Hi Boris,
In my app that column is hidden by default. But I think I can overcome this issue by applying this resize whenever the hidden property changes for that column.
I am not able to mark your post as answer so that it will be useful for others too, may be because this is not my post initially.
Nitin Jain
Nitin,
This is how it looks in my sample, I also attached the sample itself, the version is 8.3:
Thanks for the sample.
I applied the changes in my code and there is an issue:
The first column which is of boolean type and is showing a checkbox is distorted (Please see snapshot)
Wondering even after passing the last param as true why this is happening.
The following approach works just fine for me:
foreach (UltraGridColumn col in ultraGrid1.DisplayLayout.Bands[0].Columns) col.Width = col.CalculateAutoResizeWidth(PerformAutoSizeType.VisibleRows, true);
Please take a look at the sample attached to this post. If it does not work for you, please modify my sample so it reproduces the issue and send it back to me. I will be happy to take a look at it.
