I have a set of data that for each date, I have 2 pieces of numeric data. For example:
Date Value1 Value2
01/01/2008 10.5 2
02/01/2008 20.6 4
03/01/2008 30.7 6
04/01/2008 40.8 8
I am trying to represent this on a line chart where "Value1" is plotted against the Y-Axis and "Value2" is plotted against the Y2-Axis. I can create a set of NumericTimeSeries and add NumericTimeDataPoints using the date and the value in the "Value1" column. I then add these NumericTimeSeries to the chart's Series. The time series lines show up like expected.
I am also creating a different set of NumericTimeSeries with NumericTimeDataPoints using the same dates and the value from the "Value2" column.
How do I show this time series in the same chart so that "Value2" uses the Y2 axis instead of the Y axis that the "Value1" column is using?
you can see the source code if you browse to it from here: http://samples.infragistics.com/2008.3/WebFeatureBrowser/Default.aspx
it's under webchart / composite charting / multiple Y axes.
if you just change the OrientationType of one of the AxisItem objects to Y2_Axis, that axis will appear on the right side of the chart.
I tried clicking on everything on that page but could not find a link to the example of how to do it. It only says that you can do it. It showed a picture of a chart with 4 Y-axes to the left. I was hoping to use the Y axis (on the left) for one set of data, and the Y2 axis (on the right) for the other set of data.
You need to create a Composite chart with two LineChart layers, each one using a different Yaxis.
https://ko.infragistics.com/samples/aspnet/chart/multiple-axes-in-composite-charts
