505
Saving/Restoring Column order at Runtime, no stream
Hi
I wanted to restore column order of the grid to the layout in the form_load, after the columns have been moved around.  So I save it when the form loads, and trying to restore it when the button is clicked.  I don't want to use Save/Load it to/from a stream file, rather save it in an object so it can be restore later, and discarded after application closed.  Here is the code I have but it does not work:
private UltraGridLayout _layout;
private void Form1_Load( object sender, EventArgs e )
     // populate binding datasource which is the datasource of the grid
     this.bindingSource1.DataSource = datassource1;
     _layout = this.ultraGrid1.DisplayLayout;
private void button1_Click( object sender, EventArgs e )
     this.ultraGrid1.DisplayLayout.Load( _layout, PropertyCategories.All );
     //this.ultraGrid1.Invalidate();
     //this.ultraGrid1.Refresh();
     Form1_Load( sender, e );
Please help!  Thanks.
  • 469350
    Verified Answer
    You can't do it like this:
    becuase this just creates a reference to the layout, not a copy. So you need to create a clone of the original layout.
     _layout = this.ultraGrid1.DisplayLayout.Clone();
