Problem solved , have left original question below
I removed - the PromptChar character.
Issue as it was below
######################################################################################################Upon defining a cell as "double" or applying an "Ultranumeric editor" to the column it is not an easy thing to refer to the "text" - as it now appears as "______17.00"
i.e. I want to refer to 'activecell.value' and also 'activecell.text'.
What is the best way forward ?
Can the underscore be removed ? Should i strip non numeric characters ?
Change 'maskdisplaymode' , 'maskclipmode', 'maskinput'. combinations ?
