I want to disable menu and toolbar floating, and here is what i did:Right click the UltraToolbarManager and select Customize, and set AllowFloating to Flase under Settings.But this does not seem to work. When i double click on the toolbar, it still floats out of the control that contains it.
Any suggestions?
Thanks.
The AllowFloating does work.
The problem with my application is that it saves/loads toolbar settings to/from a file.When I change the property in code, it still loads the file with the old settings.
I tried it in a simple test application, and it works fine by setting AllowFloating to false.It could be something else in my application. I'll have another look.
I was not able to reproduce this behavior, but it sounds like a bug. I would recommend submitting this to the support group: http://ko.infragistics.com/gethelp.
