One of the columns in my expoted PDF has so small width that the content of the column is not readable.
I would like to set minimum width for every column.
How can I do that?
Thank you.
The grid column has a MinWidth property. You could set this on the on-screen grid or in the BeginExport event, you could use the export layout passed into the event args if you don't want to affect the on-screen grid and just affect the export.
Hi dig you got this working?
I have the same issue.
Thanks~!
