I have a composite chart with 1 area and 3 layers on it. One layer has stack column chart, two layers have line charts. I would like to set custom tooltips separately for each layer. I wrote my own IRenderLabel classes, set them as renderers for custom format strings, created the hashtable from it. I set also the appropriate format strings on the layers (I did it in designer : Chart Layer->Chart Type Appearance->Chart Text->ItemFormatString), but it doesn't work.
Is there any way to solve this problem? Thanks in advance
To do this, you need to create a Composite Chart with 2 ColumnChart layers, each of which uses a different Y-axis.
Want to set two different scales on the same y axis for a column chart
i.e.,
with a minumum range of 0 to a max of 10.. i wanna set 0 - 5 with an interval of 1 and from 5 to 10 wit 2 as the inteval..
any solutions???
Are you sure you're using Infragistics UltraChart for Windows Forms? Is the dll you're using named Infragistics2.Win.UltraWinChart.vX.x.dll ?
i dont find the data item over event handler in the events list of the ultrachart..
any solns?
Let me try to add some more color:
int oldLayerIndex = layerIndex; if (e.LayerID == "Layer One") layerIndex = 0; else if (e.LayerID == "Layer Two") layerIndex = 1; else if (e.LayerID == "Layer Three") layerIndex = 2; if (oldLayerIndex != layerIndex) CustomizeLabels(layerIndex);
private void CustomizeTooltips(int layerIndex){chart.Tooltips.Format = TooltipStyle.Custom;chart.Tooltips.FormatString = "<TOOLTIP>";Hashtable tooltips = chart.LabelHash;if (tooltips["TOOLTIP"] != null)tooltips.Remove("TOOLTIP");tooltips.Add("TOOLTIP", new RenderTooltip(layerIndex));chart.LabelHash = tooltips;}
Create a new class that implements the IRenderLabel interface. In this class you'll need a constructor to store the layer ID you're passing in, and a ToString method that implements the logic you want:
using System;using System.Collections;using System.Text;using Infragistics.UltraChart.Shared.Styles;using Infragistics.UltraChart.Resources;class RenderTooltip : IRenderLabel{private int layerID;public RenderTooltip(int layerID) {this.layerID = layerID; } public string ToString(Hashtable context) { // Add your logic here if (layerID == 0)return context["DATA_VALUE"].ToString(); elsereturn ...; }}
using System;
using System.Text;
if (layerID == 0)
else
Hope that helps! Thanks mtanska for your posts - they got me to the solution I needed!Yash.
Hope that helps!
Yash.
