Hi I've been looking around in the controls for a combo/list control that allows you to add check box options in the drop down. Funny enough I was working with the infragisitics ToolBarManager and clicked on the "RuntimeCustomizationOptions" at design time and that is exactly what I am after. It defaults to "all" and then has all the options in the list with check boxes to select all that apply.
This is also the same style of control in Reporting Services when you run a report and filter. One of the combo/listboxes has a similar tool.
OK enough rambling, is there such a tool in infragistics that I can use?
Cheers,John
Hi John,
HOWTO:Creating a Multi-Select Dropdown Combo for the WinGrid
