320
Programmatically check duplicate nodes. v8.2
gooday all,
a tree has nodes, some are duplicate nodes (i.e., representing the same underlying product).
In-memory DataTable (DuplicateNodeTable) holds duplicate nodes information.
when user checks a node, UltraTree_BeforeCheck event fires,  here i check to see if the node exists in DuplicateNodeTable.
if the node is one of the duplicate node in the table==>> get reference to the tree like so:
                        UltraTree DuplicateTree = this.dsExBar.Groups[row.Row["SchemaID"].ToString()].Container.Controls[0] as UltraTree;
try and get a reference to the node like so:
                        duplicateNode = DuplicateTree.Nodes[row.Row["treeHierarchyID"].ToString()];
row.Row["treeHierarchyID"].ToString(), is the nodes Key Property, i.e Tree.Nodes[string Key]
 an error is thrown, "Key not found Parameter name: key"
i have made sure that the Key property is initialized correctly. why is error thrown?
thanks.
