I am trying to change the color of a Row based on a value, which works perfectly. Except I need to change the row above this row as well, and this works on the first refresh of the grid, but subsequent refreshes it doesn't work because e.Row.Index is not the index but -1.
This is the code I am using:
Me.grd_Main.Rows(e.Row.Index - 1).Appearance.BackColor = cClosedControllerBlue
Any ideas why it works the first time and not subsequently?
M
Hi Shaolin,
I can't think of any reason why the Index of the UltraDataRow would change... unless you inserted or deleted a row. In which case, every row below that row would have it's index modified.
You are correct that sorting the grid only sorts the grid rows and doesn't affect the DataSource.
Hi Mike,
Yes, I meant to say "get hold of the UltraDataRow". Will the index of a UltraDataRow get changed in its life time? If not, this index will be the index of my record in my data list. My assumption is that the index of UltraGridRow gets changed because of sorting but nothing will affect UltraDataRow's index in its life time. In my applications, UltraGrid sorting is disabled, so the index of a UltraGridRow should eventually be same as UltraDataRow. Could you please correct me if my assumption is wrong?
Thanks so much,Shaolin
This is such a complex scenario and there's so much going on that I am having a hard time figuring out how to assist you with this.
Does the InitializeRow event on the grid fire again at some point after the data has been populated into the data Source? If so, then all you have to do is ignore the InitializeRow when the Index is -1 and when it fire again later, it will work fine.
If not, then there are two ways I think we can approach this. One is for you to try to work around the issue and prevent the InitializeRow from being called before the data is populated. As I recall, you pointed out how to duplicate this behavior using one of our samples, but the problem depends on a number of very specific things happening in order. For example, the problem only occurs when you call ExpandAll on the grid's Rows collection before it has painted the first time. So one potential workaround would be to defer the ExpandAll until after the grid paints. You could easily do this by hooking the Paint event of the grid. The first time it fires, you call ExpandAll and then unhook the event.
If that doesn't help, there may be other ways to work around the issue.
If none of that helps, then I could write this up as a bug for our developers to look into and see if the current behavior is correct or not, and if not, see what we can do about fixing it.
Shaolin said:Is there an easy way for me to get hold of the UltraGridRow by using the UltraGridRow object?
This question doesn't make sense, but I assume you meant to say "get hold of the UltraDataRow". The answer is yes - you can get use the UltraGridRow.ListObject property to get the underlying data object from the data source, which in this case will be an UltraDataRow. I'm not sure how that helps you, though.
The InitializeRow event is fired before any cell data is requested by UltraDataSource. My grid is in virtual mode.
Shaolin said: I also noticed that IntinializeRow event was fired before any column data was requested: InitializeRow - band: 0, row: -1InitializeRow - band: 1, row: -1InitializeRow - band: 1, row: -1InitializeRow - band: 1, row: -1InitializeRow - band: 1, row: -1InitializeRow - band: 1, row: -1InitializeRow - band: 0, row: -1 CellDataRequested - Band = RootBand; Row = 0; Column = ID; Data = 0; CellDataRequested - Band = RootBand; Row = 0; Column = Col0; Data = 459239609; CellDataRequested - Band = RootBand; Row = 0; Column = Col1; Data = 262; CellDataRequested - Band = RootBand; Row = 1; Column = ID; Data = 1; CellDataRequested - Band = RootBand; Row = 1; Column = Col0; Data = 1431531252; CellDataRequested - Band = RootBand; Row = 1; Column = Col1; Data = 263; CellDataRequested - Band = ChildBand; Row = 0; Column = ChildCol0; Data = 0.73772578441432; CellDataRequested - Band = ChildBand; Row = 0; Column = ChildCol1; Data = 31; CellDataRequested - Band = ChildBand; Row = 1; Column = ChildCol0; Data = 0.229192165298943; CellDataRequested - Band = ChildBand; Row = 1; Column = ChildCol1; Data = 32; CellDataRequested - Band = ChildBand; Row = 2; Column = ChildCol0; Data = 0.927423017065703; CellDataRequested - Band = ChildBand; Row = 2; Column = ChildCol1; Data = 33; CellDataRequested - Band = ChildBand; Row = 3; Column = ChildCol0; Data = 0.914841804613751; CellDataRequested - Band = ChildBand; Row = 3; Column = ChildCol1; Data = 34; CellDataRequested - Band = ChildBand; Row = 4; Column = ChildCol0; Data = 0.0830325270458276; CellDataRequested - Band = ChildBand; Row = 4; Column = ChildCol1; Data = 35;
I have my data records which are filtered and sorted in my own data source. My UltraGrid is just a window to display a portion of my data. I am trying not to use row.Cells for performance reason.
Each UltraGridRow must be mapped to a UltraDataRow. Even the index of the UltraGridRow is -1 but the corresponding UltraDataRow must have a valid index. Is there an easy way for me to get hold of the UltraGridRow by using the UltraGridRow object? This row index is important to me because it is also the index in my own data source list.
I don't understand your question.
If you want to base the color of the row or cell on a value in a cell of that row, what does the index of the row have to do with it? You don't need a row index to access a value in a cell. You simply use:
e.Row.Cells[columnName].Value
