If I have a pane that starts out DockedLeft and I drag that pane to now be floating, when I go to redock it at the original dock location of DockedLeft or to a new dock location of DockedTop, I get the following error:
System.NullReferenceException was unhandled Message="Object reference not set to an instance of an object." Source="Infragistics2.Win.UltraWinDock.v8.3" StackTrace: at Infragistics.Win.UltraWinDock.TabManagerBase.get_InterTabSpacing() at Infragistics.Win.UltraWinDock.TabManagerBase.Infragistics.Win.UltraWinTabs.ITabProvider.get_InterTabSpacing() at Infragistics.Win.UltraWinTabs.TabManager.get_InterTabSpacingResolved() at Infragistics.Win.UltraWinTabs.TabManager.InitializeFirstDisplayedTabItem(ITabItem tab, ScrollType scrollType, Int32 scrollIncrement, Boolean fireScrollEvents) at Infragistics.Win.UltraWinTabs.TabManager.VerifyFirstDisplayedTabItem() at Infragistics.Win.UltraWinTabs.TabManager.VerifyMetrics() at Infragistics.Win.UltraWinTabs.TabManager.GetRequiredSize() at Infragistics.Win.UltraWinTabs.TabManager.GetRequiredExtent() at Infragistics.Win.UltraWinDock.UnpinnedTabArea.UpdateSize() at Infragistics.Win.UltraWinDock.UnpinnedTabArea.AddUnpinnedPane(DockableControlPane pane) at Infragistics.Win.UltraWinDock.UnpinnedTabArea.ProcessRemovedGroupPane(DockableGroupPane group) at Infragistics.Win.UltraWinDock.UltraDockManager.FixUnpinnedAreasForRemovedGroup(DockableGroupPane oldGroup) at Infragistics.Win.UltraWinDock.UltraDockManager.RemoveUnreferencedGroupPanes() at Infragistics.Win.UltraWinDock.UltraDockManager.RemoveUnreferencedDockAreasHelper() at Infragistics.Win.UltraWinDock.UltraDockManager.RemoveUnreferencedDockAreas() at Infragistics.Win.UltraWinDock.UltraDockManager.ResumeLayout() at Infragistics.Win.UltraWinDock.DropLocation.ProcessDrop() at Infragistics.Win.UltraWinDock.DragManager.EndDrag() at Infragistics.Win.UltraWinDock.DragManager.ProcessMouseUp(MouseEventArgs e) at Infragistics.Win.UltraWinDock.DragManager.MouseUp(MouseEventArgs e) at Infragistics.Win.UltraWinDock.DockControlBase.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(ApplicationContext context) at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[ commandLine) at GMSB.My.MyApplication.Main(String[ Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81 at System.AppDomain._nExecuteAssembly(Assembly assembly, String[ args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[ args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
It doesn't point to a particular line of code in my app, so I'm not sure how to resolve this issue.
Yes it has. It was not working for me when I was using version 8.3.20083.1009, but now that I've installed version 8.3.20083.2039, it is working fine.
Has this bug been fixed yet? Any workarounds? I'm seeing the same issue.
This looks like a bug. I would recommend submitting a sample reproducing the issue to the support group: http://ko.infragistics.com/gethelp.
