460
Scrolling speed up?
I have recieved the following email from one of our users, and was wondering whether anyone thought this were a feasible suggestion to fit into an UltraGrid, and if so how would you go about fitting this into the scrolling / painting mechanism used by the UltraGrid?
"i was just wondering if you could get a rendering speed up on the main bug listview by using a P/Invoke call to the Win32 ScrollWindowEx() function to scroll the screen then only render the small amount that's necessary?
something like this should do the trick:
    [DllImport("user32.dll")]
    public static extern int ScrollWindowEx(IntPtr hWnd, int dx, int dy, IntPtr scrollRect, IntPtr clipRect, IntPtr hrgn, ref Rect updateRect, uint flags);
then you can call ScrollWindowEx() with the listview 'Handle' to scroll the window up and draw the small amount at the bottom that needs rendering.
Chris
