I'm installing the winforms part of NetAdvantageSelect20083 on our build server and even though the installation was successful for my computer (with the same key), I'm getting "CD-Key you have entered is not valid". I didn't have this problem with previous versions. Do I need a different CD-Key for our build server, even though there's no development going on there?
Yes! Rebooting the computer solved our problem.
You should not require a separate license key for your build server, so long as the installation is being performed by an already-licensed user.
There are a few common solutions for this issue:
If none of this resolves your issue, then my best advice is that you submit a support request, detailing what steps you've taken so far. A Developer Support Engineer will look into this further and provide assistance.
