907
Is there any way to set FullRowSelect in Tile view?
Or for that matte a way to change the highlight area?  I have a range of text values of which the smallest is 'Alert'.  When you select an icon only the text is highlighted.  Since the text is barely 25% of the height of the icon and only a few letters across, the selection can be hard to see with the Application Style our graphic designer has chosen for a given client...
 In the case of 'Alert' the highlight is less than 15% of the total space that appers to be available for that selection.   My icons a listed vertically in 1 column and I have a series of vertical list views that change as selection change as you progress to the right to lead to a final confiugration choice...
This user control originally used the MS list view, which provided a better selection mechanism, but of course lacked the appearance properties the GD needed to provide a seemless look for the client...  So either I missing some obvious properties or I am using the wrong view for what I want.  Though the GD really prefered the icon size of Tile view...
