1210
How to select Ultra grid row using Keyboard?
Hi Mike,
Is there any short cut key to select entire row in the ultragrid using shortcut?Or can we set short cuts programmatically if any shorcut is not there?I am able to change shortcut but I didnot find there any property to set new shortcut.
Thanks & Regards,
Ganesh
  • 510
    You can select entire row in UltraGrid by default shortcut key: Ctrl+Space
    You can change this default shortcut key by change Grid.KeyActionMapping
    Goodluck
