i'm using the AppStyle application to create a new style for the grid. Look at the picture, the Grid on the left is within a form, instead on the right is what i see on the appstyle application.
The first problem is that, as you can see, the upper or top border of the column header is not visible on the windows form and also the left border of the "boolean column" is not visible.
The second one is on the "datetime column"(left grid). In that column i simply hovered with the mouse and the grid draw that border, but on the right grid, doing the same action, nothing happen(which is the correct behaviour that i want to achieve).
the last one :), the height of the column header are different!
How can i fix these problems?
thank you
I'm not sure. I figured that the HeaderStyle was the cause of all three issues. I'm afraid I'm out of guesses as to why it appears differently in your application than in the AppStylist canvas.
Perhaps you can Submit an incident to Infragistics Developer Support and include your isl file and a sample project and maybe that can track down the differerence.
You are right. The headerstyle is set as windowsxpcomman(but these are the default settings of the grid if you drag a grid on a form).
now, the problem with the hover action is solved. What about the other 2 questions?
thank you.
