We have a small issue with the UltraWinGrid. It seems like some of the white spaces use more space as long as a cell is not in edit mode (and therefore less of the text in the cell shows). When a cell is clicked and becomes editable, the white spaces shrink and more of the text shows.
Can we set a property to change this behavior?
The grid draws text using GDI+. When a cell goes into edit mode, the grid displays a DotNet TextBox control over the cell, and the TextBox uses GDI text rendering. If you want it to be consistent, you could set the grid's TextRenderingMode to GDI.
