I use MouseMove event to change the color of row when mouse hovers on rows. I also implemented multiple row selection. The selected multi rows display in a different color by default (I did not do any change). The problem I am having is the color of all the multi selected rows has changed as expected, except the row where the mouse stops. How do I make this particular row to change to the same color as all other selected rows.
Also I would like to know how do I customize the color and look of the selected rows.
The following the how I implemented to have row changing color when mouse hovers over.
private void ultraGrid1_MouseMove( object sender, MouseEventArgs e ) { UIElement el = this.ultraGrid1.DisplayLayout.UIElement.ElementFromPoint( new Point( e.X, e.Y ) ); if( el != null ) { UltraGridCell c = ( UltraGridCell ) el.GetContext( typeof( UltraGridCell ) ); if( c != null ) { if( c.Row.Cells[ "Type" ].Text == "RED" ) { this.ultraGrid1.DisplayLayout.Override.HotTrackRowCellAppearance.BackColor = ColorRedHot; this.ultraGrid1.DisplayLayout.Override.HotTrackRowCellAppearance.ForeColor = Color.White; } else { this.ultraGrid1.DisplayLayout.Override.HotTrackRowCellAppearance.BackColor = ColorBlueHot; this.ultraGrid1.DisplayLayout.Override.HotTrackRowCellAppearance.ForeColor = Color.White; } } } }
I'm not sure what you are asking.
To change the selected appearance of a row, you would use the SelectedRowAppearance. Does that answer your question?
