335
Change font size of the application
hi,
I have a windows form application. Is there any easy way that I can change the font size of the whole app using any of the Infragistics controls? I need something like a button that when clicked, increases the font size of the whole windows application.
Sorry this is not the correct sub-forum to post this. But I don't know where this subject should go.
Thanks in advance.
Tony.
  • 469350
    Verified Answer
    Hi Tony,
    Most controls pick up their default font from the form they are on. So changing the Font on the form(s) should work - unless you have set specific fonts on your other controls.
    Another option might be to use Application Styling. You could create a style library in code and set the font on the base UIRole. Check out this thread: Change font at runtime - Infragistics Forums
