80
pass row between 2 forms
hi; i have 2 forms that one has a wingrid and the other one has a webcombo. They both have the id column that refers to same record. When user doubleclicks a row in wingrid i want to open the second form and select the record from wincombo. is there any sample?
  • 469350
    You are mixing WinGrid and WebCombo in the same application? Or did you mean WinCombo?
    I don't know of any samples of this, but this should be fairly simple. You can get the id from ActiveRow in the grid and use that to set the Value of the WinCombo - or any other control.
