Hi, Where can I find the source code for the examle used in the wintree video? http://ko.infragistics.com/dotnet/netadvantage/winforms/wintree.aspx#Overview
Thanks!Steve
I finally found the source code! Thanks guys!
To run these samples, after you've installed the SDK, take a look in your Start menu under the following path:
"Infragistics -> NetAdvantage for .NET 2008 Volume 2 CLR 2.0 -> Experience NetAdvantage for .NET -> WinForms Samples"
The actual source code will be in your "shared documents" directory:
Under XP: C:\Documents and Settings\All Users\DocumentsUnder Vista: C:\Users\Public\Documents
I have installed NetAdvantage8.2 SDK but I still can't find sample dir. Is it possible for you to send me a copy?
Thanks!
I may be wrong, but I think the samples no longer install by default. They are in the NetAdvantage SDK, now, which is a separate download. I think they do that to keep the installer size down. You should be able to get the SDK from the Infragistics Web site.
My Infragistics Keys and Downloads - Download Anything and Everything You Own
I don't have sample dir. my version is NetAdvantage for .Net 2008 Vol. 2 CLR 2.0.under windows Forms dir, there are only AppStylist for Windows Forms, Bin, and Bin-Signed
