4341
UltraToolbarManager - Font Size
Hello Team,
We are using UltraToolbarsManager 8.3, we are setting font size of the ribbon bar (Appearance -> Font Data), which is applied to the ribbon tabs and its groups items.
At the runtime the font size on the ribbon tab is different from its group items font size. Please find attached the screen shot showing the difference .
  • 44743
    I can't see the difference in the screen shots. However, if you are seeing a difference, make sure you have SaveSettings set to False while you are still designing your Form. If your application's version number doesn't change and SaveSettings is True, any design-time settings will be lost and all settings from the previous run of your application will be used. If it is already False and you are still seeing the problem, it could be a bug and I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
