615
Unwanted tabswitch back to original tab
I've got a form containing a mdi tab control. Now if I normally add a new form it displays o.k. But when I add a new form from a form other than the parent (a popup) then when I return to the parent the original active tab is displayed again. If I check the tabchaning event I can first see it change to the correct tab (after adding the mdi child), but after that it gets restored to the originally selected tab again without proper reason (it's not originating from my code that is).
Any idea's? I've tried setting:
MdiTabGroup tabGroup = _ultraTabbedMdiManager.TabGroups[0];
tabGroup.FirstDisplayedTab = tabGroup.Tabs[tabGroup.Tabs.Count - 1];
tabGroup.Tabs[tabGroup.Tabs.Count - 1].Activate();
but that doesn't change anything, it keeps reverting itself back to the originally selected tab.
