860
namespace problem with designer generated code
I have a project whose default name space is Wearther and form in the project which is in this default namespace. I have added a WinGrid to the form in the designed. I have also generated a dataset and adapters to access a table in a database. Using the WinGrid designed I have set the datasource to this dataset via the geenrated DatasetBindingSource.
The problem is that the code the designed generates includes the lines
this.wEATHERDETAILSTableAdapter = new Weather._WeatherDetailsDataSetTableAdapters.WEATHERDETAILSTableAdapter();
this._WeatherDetailsDataSet = new Weather._WeatherDetailsDataSet();
 which explicitly specify the Weather namespace although the class is in this namespace and so the compilation fails unless I remove the namespaces by hand.
How do I stop the designed from setting the namespace explicitly.
 Pat
  • 469350
    Verified Answer
     Hi Pat,
        This has nothing to do with the grid, this code is all generated by Visual Studio. I think you might get better results posting this question on a Microsoft forum or to Microsoft support.
        Personally, this has never happened to me.
