585
Dockable Pane displaying in designer but not at runtime
I'm having a really tough time with this one.
I have a winform application with 2 dockable panes that flyout and hide as tabs.  One docks to a tab on the left, the other to a tab on the bottom.  In the designer, they both appear and fly out as expected.
However, when I run the application in debugger, only the one on the left appears.  The one ot the bottom just isn't there, no tab, no pane.
Things I've tried:
 - pinning the pane in the designer (still no pane at runtime)
 - programatically running the flyout() method to see if it would display (no pane).
 Any advice on how I should debug this would be greatly appreciated.  Thanks so much.
Steve
  • 44743
    Make sure you have SaveSettings set to False on your dock manager. It sounds to me like settings from a previous debug run are overwriting your latest design-time changes. If that is not the case, it could be a bug and I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
