762
Drawing a sliding panel between the ribbon and top grid
I have a WinForms application with an UltraToolbarsManager containing a Ribon, and a MainForm_Fill_Panel containing two UltraGrids and a Splitter. My application periodically gets alerts from a server, which I would like to write to a sliding panel that appears below the ribbon and above the top grid in the Fill panel
By "sliding panel" I mean the top grid visually shrinks vertically on the screen, hiding the last few rows of the top grid, and opens up a space above the grid where I can write the alert text. When the alert is over I want to visually expand the grid, revealing more rows. Is there an Infragistics control that can do this, or a tutorial on how to accomplish this? If necessary the panel does not have to slide, it could just redraw the Fill panel with a smaller grid and the alert text above it, but it needs to be a separate control and not part of the grid.
