515
UltraComboEditor not retaining initial text value
We are porting an application from Infra 6.3 to 8.2
The following code snippet illustrates a problem we are having with the UltraComboEditor.
When run under 6.3, the editor displays text="Howdy"; under 8.2 text is blank. If the first item in the list is not blank, then it works fine under both releases.
I would like it to behave like 6.3. I realize that putting uce.Text="Howdy" after Show() has been called will work, but is not possible in our situation.
Any help/explanation will be appreciated.
private void Form1_Load(object sender,EventArgs e)
 uce.Items.Add("");
 uce.Items.Add("A");
 uce.Text = "Howdy";
private void InitializeComponent()
 Infragistics.Win.Appearance appearance1 = new Infragistics.Win.Appearance();
 this.uce = new Infragistics.Win.UltraWinEditors.UltraComboEditor();
 ((System.ComponentModel.ISupportInitialize)(this.uce)).BeginInit();
 this.SuspendLayout();
 // uce
 this.uce.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
 appearance1.BackColor = System.Drawing.Color.WhiteSmoke;
 this.uce.Appearance = appearance1;
 this.uce.Location = new System.Drawing.Point(32,77);
 this.uce.Name = "uce";
 this.uce.Size = new System.Drawing.Size(144,17);
 this.uce.TabIndex = 1;
 this.uce.TabStop = false;
 this.uce.UseOsThemes = Infragistics.Win.DefaultableBoolean.False;
 // Form1
 this.AutoScaleDimensions = new System.Drawing.SizeF(6F,13F);
 this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
 this.ClientSize = new System.Drawing.Size(284,264);
 this.Controls.Add(this.uce);
 this.Name = "Form1";
 this.Text = "Form1";
 this.Load += new System.EventHandler(this.Form1_Load);
 ((System.ComponentModel.ISupportInitialize)(this.uce)).EndInit();
 this.ResumeLayout(false);
 this.PerformLayout();
