490
CalendarCombo prevent (none)
 I have CalendarCombo and the user can DropDown and select the date my Question is : how we can prevent user to clear calender(make it none) because I am using the following code in CalendarCombo1_AfterCloseUp event and it's give me input string error :
                DateTime enterDate = DateTime.Parse(CalendarCombo_From.Value.ToString());
                DateTime todayDate = DateTime.Parse(CalendarCombo_To.Value.ToString());
                int val_end = DateTime.Compare(todayDate, DateTime.Now);
                if (val_end != 1)//if Date To bigger than today date
                    int val = DateTime.Compare(enterDate, todayDate);
                    if (val == 1)//if Date From bigger than Date To
                        CalendarCombo_From.Value = DateTime.Now;
                else
                    CalendarCombo_To.Value = DateTime.Now;
