I need some help. I need to know how (or if it's possible) to set my date time format to a Julian day style format meaning yyyy:DDD:HH:MM (where the DDD is the day of year number, for example Feb 1 would be 032)
Any help would be greatly appreciated!
Greg
Yeah, I didn't see my format in any of the MS formats...
Hi Greg,
If it's possible to do this, it would be via the DateTimeFormat property of the panel. This panel essentially just takes the Date and calls the ToString method on it and passes in the format. So what you will need to do is check out the Microsoft Documentation on DateTime.ToString and see what the allowable formats are.
If there is no format that does what you want, then another option would be to use a DrawFilter and draw the text of the panel yourself.
