907
Having a wierd compile problem...
I was getting the following error during compiles: Not enough storage is available to process command
Read some articles that suggest I remove uneeded references...  I remvoed about 7 Infragestic references that I wasn't using and the compile problem went away...  I wasn't actually expecting it to work, now that it has...  If there an easy way to determine which Infragestic DLL's I'm actually using?
